- May 13, 2024
- Virginia/DC
- 2.3 (4 Cylinder)
Happy to be here, I picked up my 2011 XLT, 2.3, 5spd, RWD, 91k miles in January and so far I love it. It's from Akron, OH so it has seen some salt and winters. Are you on here, original owner? That would be wild, Carfax says it was a one owner who bought it new, drove until last year, then traded it in at the dealership he bought it from. Maybe traded on a new one?
I started with the basic new-to-me maintenance stuff; changed/flushed all fluids & new filters. Found oil in two of the spark plug tubes, so I pulled the intake and valve cover off and replaced the valve cover gasket, seems to be good now. New coil pack, spark plugs/wires, and exhaust from the cat back because of rust. Shortly after finishing that is when the bug bit me I think. I filled up a shopping cart on Rock Auto 'just to see' how much it would cost, and ended up overhauling most of the suspension! All new upper and lower control arms, bushings, ball joints, inner and outer tie rod ends with new baffles, sway bar links and bushings, 4x Rancho shocks, rear leaf spring mounts and shackles (rust!). I even took the leaf springs off and completely apart to put in polyurethane bushings, grind off surface rust, treat with rust reformer and paint. Had to replace the OE spring clip and plastic insulators and I took the opportunity to add-a-leaf for good measure.
I found during the first oil change that the drain bolt was over-torqued and it must have been done by the dealer right before listing it on their used lot because the thread pieces came out with it. Anyone had any luck with the carbide drill bits that can cut in new threads? I picked one up off Amazon which will then convert the plug to an M15 instead of M14, but I haven’t tried it yet, any opinions on that would be appreciated.
Cheers!
Cheers!
