Heater Core?????
upriverjoe
88,Bll,2.9, i'm 67 and don't have a manual, where exactely are the bolts or screws located for R&R heater core??????
THANKS ALOT
There's only about 5 8mm (think) bolts that hold the plastic cover on. It the plastic cover beneath the core. Right above where the passengers feet would be. Then undo the hoses from under the hood, maybe plug the ends so coolant doesn't spill on the floor. Then pull it back and down. Try to crawl under and have a look, the bolts are easy to find.
