Heater Core
anupaum
RBV's on Boost
It's been on its last legs for awhile, but I've been reluctant to do anything about it. Why, you ask?
Because the supercharger is in the way . . . It's in the way of EVERYTHING.
The heater core itself loosens easily enough, but the hoses that connect it to the engine block are right behind the blower's intake plenum. I had very little room to work with, and wound up chewing one of the hose ends to shreds with a pair of vice grips to remove them. The throttle cable and a vacuum fitting off the plenum were also in the way.
Ugh!
So, after offering the appropriate blood sacrifice to the angry deities of auto repair, I have the heater core out . . . Now, I need to replace the hoses too. And while I'm at it, wouldn't it be nice to get the fan working again? Last winter was a nightmare without a window defroster . . .
The things we do for boost . . .
Bad news on the heater motor front . . . I tested the motor today by applying 12 volts directly to the motor, but it didn't spin. That means I have to replace it, which involves taking the blower off again. (What a pain!)
I really need to find a better solution to the heater fan issue.
