Heater Control Valve
that_one_guy
The end of the Oregon Trail
Ok well i Replaced mine when I bought the truck 2 years ago with a motorcraft and the other day i notice its leaking again! Is there a better option. This is getting retarded.
Are you talking about the "H" valve in the engine to heater core hoses?
You could replace it with a bass fitting setup with two valves. The problem with that is that it becomes fully manual operation. If you want automatic operation, buy another motocraft valve.
It's the only way I know of ....
You don't really need one.... It just shuts it off when max AC is used.
the line that goes to mine was off and there was a screw in it from the previous owner. What would that do? It was leaking before i replaced it
