heat on feet
snoman6115
Weston, WI
it seems only to do this when im on the highway with all AC and heat turned off. it will still blow warm air on my feet and its very anoying on hot days. any ideas?
ah ha i figured out it was jsut the blend door. fixed that and the heat on my feet stopped and my ac blows great
Ugh! I have this same problem and I'm looking for ways to fix the blend door.
I have some questions!
How did you fix yours?
Where is the blend door located?
Thanks in advance. :)
different systems.... you've got a wire/vacuum actuated system and snoman has an electric motor actuated system... read through the following thread to what actuates max a/c in your system which basically shuts down air from outside and what actuates your blend door (temp lever):
http://www.therangerstation.com/forums/showthread.php?t=54945
Hope this points you the right direction :icon_thumby:
well now idk cuz the fix worked for a day and now its all broke again and i have no idea, im thinking the wentire blend door is shot but i really dont want to take the entire dash apart to find out
Did you follow the blend door fix thread?
yea and like i said it worked the rest of the day and the next day when i tried it i only had max ac again, took it get diagnosed and i had like 25 low and 175 high so im thinkin its jsut teh blend door itself that is broke?
