- Dec 10, 2008
- Warrenville IL
- Automatic
Totally agree Mike, it's the Explorer computer that causes the problem. He should already have the 65mm TB and larger MAF from the Explorer. If he was to stay with the Ex set-up, I was going to reccomend the Comp Cam XE264HR-14. Long winded explaination about the LSA and duration at the bottom.
http://www.v8-ranger.com/forum/viewtopic.php?f=6&t=1981
Dave
I'm a bit confused now....
WHICH mustang ECU should I be using??? My truck is OBD2, I can't imagine that the 94-95 5.0 mustang ECU's will still plug right into my harness and work correctly? My truck is honestly 'grey area' exempt right now as it is still registered to a different county where it isn't eligible to be tested... I was 'trying' to stay with the explorer ECU because I can 'bluff it out' enough to pass if ABSOLUTE need be... but if a mustang ECU is the way to go, so be it, I'll just renew the tags for Ottawa.
If I DO use a 94-95 Mustang ECU, how in the world do I tune that!? What needs to be done to adjust the explorer MAF/intake/heads already on it in that case?
The Cam 'limiting' factor is the ECU and not the motor? If thats the case, couldn't I bring the truck to a place like Anderson motorsports and have them do a stand-alone? *I know it would be pricey, but wouldn't I get the best gains out of doing something like that instead? or is it easy/cheap to use a mustang ECU for the application in my 98 truck?
What exactly does my motor have already 'on' it (Its already a hydralic cam correct? And also... what EXACTLY does that mean, should I just Wiki it?)
