headlights backwards
osteologation
got this ranger and the brights work in the dim position and vice versa. also bright indicator is always on. any ideas. tried searching but i cant seem to find a similar problem. ive scoured the harness and i cant find any signs of molestation. could it have the wrong mf switch?
It is also fairly easy to swap the pins on harnesses with a very small screwdriver.
Either insert it in the top or the bottom and push the retaining tab back and slid out the wires and swap em.
this is what i did, but the bright inidcator is still always on. i will try the 9004 as the 9007 are in it.
