broncobuckinaround
- Sep 24, 2012
driving to work and b2 shuts off. smokes starts coming from under the hood. found that an orange fusible link decided to burn up.
i replaced the starter switch cause it was coming apart. didnt see anything wrong with the head light switch.
ive found that when the headlights are on the wire is grounding causing the in line fuse i put in to replace the link. btw that fuse is 30 amps.
being the power wire coming off the starter relay shouldnt have ground going to it.
my apologies if this makes no sense.
burnt fusible link, replaced with 30 amp in-line fuse, pops running or not seems like but not sure. could be starter switch or could be headlight switch i need help diagnosing this
