The Fonz
- Feb 15, 2012
- Automatic
I recently bought a Bronco II to cruise around in while I work on my 76' Volkswagen Westfalia. The issue i'm having is that the headlights will flicker and turn off after I hit the highbeam/turn signal switch. I switched out the headlight switch already which fixed the instrument lights, also the turn signals work fine and the fuse is okay. Basically my question is if I go and drop $60 on a new turn signal assembly will that fix my problem? Is there a common wire issue in Bronco II's? I'm hoping to get this fixed by tomorrow night so I can drive to Philly for a Flyers game
Thanks,
The Fonz
Thanks,
The Fonz
