Headlight Circuits?
QNev
This is a little weird. Thought I had a burnt out headlight but noticed both were working as daytime running lights. As soon as I pulled the headlight knob out and turn the night time lights on, the left one shuts off. And I'm pretty sure both came on with the high beams.
How do the circuits work on the headlights, and would I have a short? Is there anywhere where I could order a new harness (or is replacement possible/easy)?
Thanks.
if your your one low beam still works its just that your low beams are burnt out. The DRL or day time running light module only runs the highbeams on a lower voltage so you can have no low beams but your drl will be working fine since it uses the high beam filaments hope this helps.
jbaum
Yup, its working as normal, just replace the bulb.
