adsm08
Senior Master Grease Monkey
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
Ok, so I have some new Headmans that I am going to coat with actual exhaust coating. Problem is I have to get the black shipping coat off. I was originally told to just use brake cleaner to get it off. That didn't strip it off so much as make it gooey, so now I am looking for the quickest, most efficient method available.
Things I have:
Scotch-brite
Sandpaper
half a can of crappy brake cleaner
wood stripper
brake fluid
a wading pool
razor blades
Things I do not have:
bead/sand blaster
good brake clean
paint thinner
a battery charger
patience
wire brush
Alright guys, lets hear your Apollo 13 ideas.
Things I have:
Scotch-brite
Sandpaper
wood stripper
brake fluid
a wading pool
razor blades
bead/sand blaster
good brake clean
paint thinner
a battery charger
patience
wire brush
