Zer0PSI
Anyone know where I can find new header bolts for a 94 Ranger?
Sure they do. The Metric system for bolt material "toughness" is a bit different, I believe they refer to the harder bolts as "10.4". It's been a while, I'd have to pull a catalog to double check the exact nomenclature though.They don't make metric 8 grade.
A Metric grade 10.9 bolt has the same 150,000psi tensile strength as an Imperial grade 8 bolt. As for finding a small headed "header" bolt in Metric, your not going to find an Imperial version at Central Tractor either.My point was that they do not make 8 grade metric bolts.
They are available, in various lengths, at about $1.85 each.Personally I'd rather put in studs if they're available. I know that's what I'm going to do on my 2.8L.
