 - Aug 13, 2007
 - Illinois
 - Automatic
Yes, there is a chance the catalytic converter is clogged......
BUT, catalytic converters DO NOT die, they are MURDERED. There is no reason why a catalytic converter would die, really not even age. It's usually physical damage or the engine is running rich, coolant is entering the cylinder (therefore exiting and contaminating the cat), or excessive oil burn(also contaminating the cat). Find the contaminate, replace the cat (if needed), and you'll solve the problem.
Symptoms would include....strong smell of gas???? Little things like this, or maybe high rpm,etc.. may point to common symptoms of a component failure. Help us, help you.
But with the drop of MPG, you are obviously using more gas. But there is a reason your computer thinks your engine needs more gas. It's tricking itself. Testing the ECT would be my first step.
Wouldn't hurt to check the FPR, pull the vacuum hose off the top and see if gas comes out. If so, BAD. Another check would be to place a vacuum on it and see if it holds 25psi for a few minutes.
