Headache!!!
SmittySTX
Ok so this is what ive done so far
- new battery cables
- new starter relay( 34$ for a Niehoff one from Lordco Auto Parts)
- new igniton switch
- newer starter from the junkyard
When I try to start my truck the starter will not disengage, it has done this with my old starter and the one I got from the junkyard. Do you think I should buy a new starter? Will it solve the problem Because I have no idea what to do next, Ive pretty much replaced the whole starting system.
Do what he said. Take the starter to a auto parts store and have it tested. They usually do that for free. This way if it passes you can eliminate the starter as a problem.
I have usually found though that junkyard electronics such as a starter are bad.
