I picked up my first Ranger (1993, 4x2, automatic, 3.0L) this summer. It had been sitting for a while, and the bolt that held the distributor in place was loose, so the timing was all kinds of whacky. Didn't have a timing light on hand at first, so I set the timing by feel after changing the plugs. I have a light now, and I wanted to do it right, but something definitely is NOT right.
I followed what seems to be the standard procedure: warm up the engine, turn it off, unplug the SPOUT connector (little gray thing by the driver's headlight), loosen the distributor, turn the engine on, set timing to 10 deg BTDC with the light, lock the dizzy, turn it off, plug the SPOUT connector back in, enjoy your new timing. Simple, right? Apparently not...
I should have known something was up because my initial reading showed way below 0 degrees, let's call it NEGATIVE 10. I cranked the distributor all the way to the right, timing went up to 10, engine seemed to run ok, maybe a little pinging, but I figured that was normal. Turned it off, plugged the SPOUT connector back in, when I started it back up, it took a lot of effort to crank, and ran awful! That's where I left it for the night.
What might be going on here? PCM issue? Was that not really a SPOUT connector? Something ignition-related not in the right spot?
Thanks in advance!
(Get it? Advance?!... I'll show myself out... )
Thanks in advance!
