86rangerxlt
Starter went bad on my truck... basically went to start it and the starter would make noise but not crank... so i replaced the starter. i fired it up and it sounded like it was grinding on the flywheel as it started. but once it was running it sounded fine. backed it out of my driveway and started off down the street. i didnt get 3 houses away when i could hear noises. so i turn around park it. and get my stethoscope out and put it to the stater i can hear it slightly. then i put it over the flywheel housing and i can really hear it. so i shut the truck off and take off the starter. the teeth on the flywheel are shiny. and i can see little metal shavings around the starter housing. altho the starter looks fine. what could be the problem here? should i add some washers under the starter to pull it back a little?
