pureroundcircle
- May 15, 2010
- Automatic
My 98 Ranger 2.5 has a poor running condition. It stumbles on acceleration (50+% throttle from about 0-25mph), and bucks really bad when trying to accelerate in OD. Idle is kind of lumpy as well. I've looked all over for vacuum leaks, have taken hoses off... I'm pretty sure that isn't part of the problem unless there is some specific location that I might have missed?
I've been trying to track this problem down for months. I replaced a bad ignition coil, but in the process of tracking it down the MAF, and TPS were also replaced.
So.... I'm pretty sure the MAF TPS, and ignition coils are good, plugs and wires have been changed. Scanner shows the MAF and TPS values and they seem good as well.
I have an autoxray scanner, my CE light is NOT on, it never blinks, and no codes are set or pending EVER relating to this problem. It is capable setting a code, if I unplug the MAF, it takes a while but a code will set.
The scanner shows 0 mph for vehicle speed, and 0.00v for both oxygen sensors. My scanner has live data and those values never change, short term fuel trim #1 fluctuates around 0% to +-5%, but short term fuel trim #2 always reads -100%? Anyhow readiness codes read OK for oxygen sensor and heater, wtf? Also ECM runs closed loop as it should.
I've tested the oxygen sensor at the sensor, it works fine. I checked output from pin 60 at the ECM, got 0v. I wired the oxygen sensor to pin 60 directly figuring the problem might be fixed. My scanner still reads 0v for O2 sensors, and problem is still there.
I've also ohmed the fuel injectors, ran fuel system cleaner, and checked fuel pressure, all seem OK.
I'm stumped. I'm thinking bad ECM? but how do I verify? I don't have much cash so I cant really be buying parts I don't need.
Anyone have any thoughts on this mess?
Thanks,
Paul
Thanks,
Paul
