"Mike Tonon",
I have some information for you today but it will be changing. I have a 1987 4WD Ranger 2.9l 5speed manual, reg. cab long bed with a 3" body lift and the Ford Hi-Ryder factory suspension lift with dual James Duff 70/30 in front and single 70/30's in the rear, completely stock engine with the following bolt-ons;
1) Thermostat controlled electric fan
2) Accell 300+ digital ignition
3) K+N air filter
4) All synthetic lubes
5) JBA headers
6) 2.25" stainless steel (SS) tubing
7) Borla SS turbo muffler
8) Ford LS4:10 front/rear
9) 32x11.5-15 all terrain tires
10) Hypertech computer chip
11) Oil cooler with thermostat controlled bypass
This truck gets
28mpg on the highway (I don't drive faster than traffic, usually 65 or less) and between
22-24mpg in town (driving like an absolute maniac). It has 133k on it and is now undrivable due to the cracked head on the passenger side.
I am installing a refurbed set of heads. I am going to add a performance valve job, hi-lift rockers, Aluminum spacers on the rocker shafts and mill the heads .025".
I will report the changes in mpg and driving characteristics.
Of all the bolt-ons the electric fan, exhaust and air filter made the largest improvements in gas mileage. When I have more time I will be rebuilding a bottom end for torque and having the heads/intakes port/polished for the same. I hope this gives you a reason to hang in there. I believe over 30mpg highway is possible and will be the result of a complete engine build with BALANCE and TORQUE as the priorities.
