- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
I suppose the is it specifically aimed at people with a 4wd 4R44E/4R55E/5R44E/5R55E cause the 4x4 version is supposed to be deeper, but I'll throw it out to all you automatic Ranger owners.
I'm about to change the fluid/filter in my 99 Ranger, and want to add a drain plug for future fluid fliter changes. I haven't actually gotten the pan off yet, but I can't tell a good place to put a drain plug in. I tried to use a siphon pump and get all the fluid out through the dipstick tube, but it appears that the pan is still full of fluid. At least I still have fluid dripping out around a couple of the loosened bolt holes. I can't be taking an ATF bath before going to work so it'll have to wait for another day. I definitely want to add a drain to make this easier for future changes. If anyone can suggest a good location to drill a 1/2" hole for the bolt in drain plug, I'll just pop a smaller hole right there and let it drain before continuing removal of the pan.
If you've done it and have a pic please post it up. As they say a pic is worth a thousand words.
