Has anybody found a decent heater control valve?
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
Central Indiana
My 01 Duratec truck seems to chew through them like candy. The Duratec seems to run a bit hotter than other Ranger engines, so maybe it just comes with the territory, but I've been replacing them about once every 12 months (roughly 12,000 miles). Motorcraft parts tend to last a bit longer, but they still fail way sooner than I'd like around 18 months. Has anybody found one that lasts longer? Maybe even one made from metal, instead of cheap plastic that fatigues when it gets hot? Anything else that might be contrubuting to the frequent failures? Everything else about the heating system works fine.
Just remove it and put in metal couplers, plug vacuum line
In 2001 the valve is only used with MAX AC setting, stops flow to heater core, so not really needed since Blend Door would be closed in any case.
Test it first
Start engine
Set Temp in Cab to COLD
Check for vacuum on Grey Vacuum line on by-pass valve
Turn Temp to HOT
Check for vacuum again
Turn on MAX AC
Check for vacuum
