Hard wiring window
chrwilkins30
Mishawaka, Indiana
Has any one ever made a way so that a power window will work on some kinda two way switch
My passenger one will not roll down. It will go up but not down. Its not the motor as i checked it right to the battery.
Help
Take the switch off the door and clean it. It probably has some dirt or debris in there not letting the contacts connect.
i swapped out 4 switches from the junk yard. Its something with the wiring. The switches will let the window go up but not down.
Did you try the drivers side switch too? There are 4 black wires coming out of the drivers side switch and they all connect to ground. If the one for the window down isn't grounded, the window won't go down. Try a jumper wire to each black wire, one at a time, at the master switch and see which one is bad.
