timmayw21
- May 10, 2008
I have a 96 4.0L 4x4 5spd that I has been shifting hard at times. It will not go into gear with out a good deal of force and will not come out of gear with out force. It seems to start to happen after driving around town in stop and go traffic, lots of use of the clutch. Its not a gradual thing ether, it will go from shifting fine one moment and then not. I can be sitting at a stop sign everything is fine and then suddenly I can feel the clutch partially engage almost as if I had let out on the pedal about half way suddenly and the truck will start to creep forward, and I have the pedal all the way to the floorboard.
Its like the clutch is not fully disengaging, Iam guessing that heat may be a factor as I can let the truck sit for several hours and the problem goes away.
We have bled the clutch twice now which only seems to slightly lessen the problem for awhile. The clutch is also relatively new with less that 10,000 miles on it.
Thanks for your help
