cozz
- May 3, 2009
90 model ranger, first start of the day, won't start unless I use starting fluid and floor it. used an obII code reader and got code 54 (iac circuit open, vane flow sensor out of range) Soo, I replaced the Iac sensor and still having same prob. Also replaced the pressure regulator at a guess before I did code reading. After I get it started once, it'll start all day long. Also when I unplug the IAC, before starting, it starts right up, course I get a check engine light.Any guesses here, thanks, Cozz
