97fordrunner
Hey all. So I am turning my '97 into a trail rig and am in the process of getting 5spd swap parts collected and plan is to make half doors and the thing I have noticed about that is when you lean on your left leg it makes it hard to operate the clutch pedal and so my though is to make lever next to the drivers seat between the door. And what my initial thoughts are is to use a cable and run it under the cab and back in through the firewall and attach it to the clutch pedal and go that route so when you pull up on the lever it engages the clutch. could even go one step further I guess and put a twist throttle on it like a motorcycle if I wanted. any thoughts? Suggestions? People done it? Thanks all
