- Mar 14, 2013
- Texas
- 4.0 V6
- Automatic
- Tire Size
- 31
- My credo
- I need more sleep.
Thats about what Im looking for. The effective range differences between the two seem pretty negligible, while I feel the longer barrel will have its advantages.
The Pardner is $190 while the Tamer is $230, so I think Im going with the Pardner. If the 20ga is still too much for my tiny wife, then I'll look at getting a tamer in .410 I think.
Can anyone comment on the functionality of slugs in a full choke? I assume the smaller diameter would effect the slug velocity, but slugs are made of relatively soft metal, so they just deform to fit. Any comments?
Slugs are made to be shot through all chokes, but shooting through a full choke is not recommended due to the immense pressure from the small diameter of the choke and it just might nick the projectile, but that's just a myth, better safe than sorry right?. With a modified you should be fine, even though the accuracy will suffer a bit. But you can pick yourself up some rifled slugs or sabot slugs. But again, don't expect it to be super accurate or have an extreme range. And since it's a choke that can't be taken out, you are going to have more structural support.
