- Jan 16, 2008
- Age
- 51
Hey all,
Growling noise underneath which increases as speed increases, and doesn't go away if I give or let off the gas. I checked the drive shaft, and there is a little play in the U-joints. Also when I twist the shaft, there is some play in the t-case and differential yokes. Is that normal? What are the other possible causes of the growling? I recently changed the wheel bearings, thinking that was the problem. No luck.
Suggestions? Thanks
Jason
Suggestions? Thanks
Jason
