Grounding problem?
Buffalo
I've been trying to diagnose my 4WD problems, and one of the diagnostics is pin 2 of connector C281B should be <5ohms when grounded, and it's not. It starts at 0 ohms and creeps up to 5.3 ohms. This is one of the grounds for the control module. Could this be a problem?
It appears this is a common ground for the DLC connector, and OBD appears to be working fine.
Touch your meter leads together and record that reading. Then do your resistance test, subtract the number you got touching your meter leads together from the number you get doing your test. This is called zeroing the meter.
I don't think that is your issue.
