guitardude2007
my 1997 ranger had the code for purge flow sensor high input. I have replaced the sensor twice to try and fix it (cheap on rockauto) code always came back. I got to futher testing and found .2 ohms at the ground on the connector. the issue I have found is that if anything is on (dome light on, key on, engine running, etc) the resistance gets high cant remember the actual reading but far above specs. I cut the ground wire off and ran it direct to battery no ground issues now at the connector but what would cause the high resistance even the ground wire off the battery to the rad support shows high resistance when anything is on. ive been cleaning up all the grounds ive found so far all where clean but being a mechanic I know that what looks clean can be a poor ground. is there any common spots I should check?
