Grinding noise!
RonneyJAyala
Eugene OR
I have a 92 Ford Ranger, trailer leveling kit(3.5") and its sitting on 31-10.5 tires. Every time I go to take off there's a slight grinding sound. It only happens in first, and only when the clutch is almost all the way released. Mind you it could be the cleanest takeoff and it'll still do it. I have no idea what the problem could be, and it's slightly worrying me. As grinding noises usually aren't ideal
Where is it comming from is it transmission grinding or does it sound like its comming from out back
Id look into clutch and slave cylinder not sure what year they started the internal slaves but my old 4.0 had the same issue with grinding and pulsing clutch pedal
Perhaps you should have a good look at the engine and transmission mounts. Could easily be the movement of these parts making the noise.
Big Jim
It's a grinding / rattling noise. Coming near the front of the truck. Only happens during a low rpm range at a take off
Brake calipers sticking...wheel bearing...heat shield on passenger side...
I had something similar that I thought was my transmission...turned out to be the left wheel bearing...which decided to disintegrate at highway speeds...
Check the front wheels for play by jacking one up at a time and prying up on it with a long pry bar or wood...there might not be much movement but any is not good...but it could also be ball joints or tie rods with that movement.
For the calipers...or front brakes in general...does it feel like it is pulling left or right when stopping or dragging when you take off?
Front hubs are another place to check if its 4x4 ive noticed that you dont get much play when there shot hows the wear pattern on the front tires
