grille questions
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
Solid Axle Swap
Plattsburgh, NY
1999
I will work in your truck, you just cut out your center section. If you scroll down a bit under "Installation" it says "cutting Required".
For the bottom grille you want a 2wd grille, you will have to cut out the center part of your grille to work. you can use your 4wd shell and keep the bars in the center.
2wd cut out
4wd cut out
i got my billet grille and i ordered a 2wd grille off ebay.. i got it today and noticed it was broke.. so iam getting another one.... so this one will be the ginny pig.. i started to cut it and like ive mentioned before ... iam not sure on the cuts...
do i have the cut out all the plastic around the grille... and leave just the "chrome face shell? cut past the grey section and up to the first lip where the chrome is..
be careful on which one you order. I have one that i ordered, but the billet is too long. The links is what i ordered, but i don't think it is right because i would have to cut out the sides of the stock grill as well, not just the center.
