my80chevette
- Feb 25, 2009
I purchased a 1988 Ranger a week ago with the 2.9 and stick. It ran but pretty poorly and I figured I would need to do a bit of work on it. The engine would start almost immediately but died right away. Then when giving it gas to keep it running it sort of surges and will die if you just keep a steady pressure on the gas. Plus it makes it a bucking bronco out of it when your in low gears. After looking on here I began checking various sensors and today I disconnected the map sensor and the truck stayed running and not surging. So this must be the culprit in my problems with the truck, right? I would check the codes but I have no check engine light and no way read the codes any other way. What do you guys think??? Thanks for any help and this site really is great!!
