honhon
- Jan 5, 2013
- Automatic
Hello all, in the middle of trying to fix my "wont shift until warm" issue with my ranger.
88 XLT 2.9L 4x4 with the electric tcase and the A4LD
tonight i decided, what the hell... im gonna drop the tcase.
got the trans supported right now by the mount underneath with a jack stand.
trans support is off obviously, i pulled the tcase out and off.
and then i pulled the governor off...
it seemed alittle dirty and/or scored so i believe i will be replacing it...
but heres my 2 questions while im in the middle of this....
#1 there was a gasket in-between the extension housing and the tcase... its obviously the original and it tore when i pulled the case out...
anyone know a part # for this gasket?
also to go along with question one.... there is fluid draining from the extension housing... i saw a picture on another forum and the guy's tranny was also doing this, so i was feeling it is normal... but i just read another post that this area should be dry and have no fluid... which means the rear output shaft seal is bad? can any elaborate on that?
#2 if you look at this thread
http://www.explorerforum.com/forums/showthread.php?t=155582
(i hope i can post another forum here... it hosts the picture im talking about)
post #3 by brooklynbay.... he posted a picture closeup of the governor broken down...
is the piston in the middle supposed to move at all? or just stay planted in the housing...?
also does anyone have part numbers for these parts?
if the piston doesnt have to move, then i think ive gotten it pretty cleaned and smooth working, but if i can get the part number's then i will deffinately replace it...
thank you all for the help!
