Christopher
- Jul 20, 2008
- Age
- 54
- 87 Ranger
Has anyone tried surge engineering stage 3 chip o2 combo? They say its adjustable and works at all throttle levels to enrich a/f mixture to desire for stock or mods on any efi system. Supposed to fool the computer and lie about the actual o2 readings. Sounds good anyhow. Finally got my spacers fabricated today for my plenum to intake mod. Havent installed yet but I will let you know. When I reset the gap on plugs the other day I noticed a different sound from the exaust. It didnt have the bass like before. I badly guessed at the gap the first time and most were set to .55 or 60. After resetting to 48 the sound was deffinitely more subdued. I think if I can get some more fuel to this engine then I will get a hotter coil and set them back to .60 Can anyone tell me where to get an inexpensive fuel pressure regulator that is adjustable and also fit,or be fabricated to fit? I only need it to go up to 45 psi max. Yall know I dont like to spend money on this stuff. I might buy that surge kit for 299.00 since I have done most of these mods without spending much dough. I would like to adjust pressure ever so slightly from 32 to maybe 40 at idle. I am going to try to increase flow first from 5/16 to 3/8 fuel line. Is hydraulic hose strong enough? I got some laying around and the quick disconnects will accept up to 3/8 hose anyhow. Any suggestions yawl? Im not trying to build drag Ranger just get the most out without spending a fortune so I can prove that it can be done. I will save the 5.0 swap for my 74 pinto.
Salute
