Ok, so heres the latest dilemma...
Trying to figure out what trans to use and a driveshaft to match for the V8. In the engine's final build... hoping to pull around 400hp and probably around 380ft/lbs at the crank (Probably wont get that high, but its a goal
). Is there a stock tranny I can pull from a junkyard vehicle that will hold up to that? Or am I stuck buying an aftermarket build? Auto preferrably, going to install a manual valvebody on it.
Which brings me to problem 2...I want to eliminate the two piece shaft and go with a single piece. Any suggestions on where I could obtain one thats the right length? Its an extended cab 2wd truck.
Any help here is appreciated, I cant seem to find any good info on this anywhere
