- Aug 28, 2007
- Durham, NC
- Automatic
I find that of the brands I have tried, the side electrode has eroded after 40-50,000 miles to the point that I start getting misfires. The plugs look fine otherwise and could probably just be regapped, but I figure if I have to pull 'em anyway, might as well replace 'em.
This is why double platinums are important. With EDIS, 2 plugs fire in series, one plug receives the negative portion of the spark, while the other plug receives the postive portion of the spark. Not only this, but they fire every revolution of the crank, twice as often as with a conventional ignition. The
negative polarity spark causes the "ground" electrode to erode.
I've posted this before, you can see how the EDIS fires 2 plugs in series. This applies to the 4.0L also:
