- Dec 1, 2007
- Age
- 41
- Prince George
Can anyone recommend a good brand of spark plugs and wires for a 4.0L OHV
Thanks
Thanks
Bob, just out of curiosity, what specifically is supposed to be the problem with the Bosch-EDIS compatibility? I haven't experienced this.
Isn't "running too hot" a function of the length of the insulator? And therefore couldn't any plug with the incorrect insulator length run too hot?
All spark plugs function in the same basic way. So what, specifically, is different about the construction of the Bosch plug that makes it incompatible with the Ford EDIS system?
Please understand, I have no doubt of your veracity, but it's just that I have used Bosch plugs -- and other brands-- and I just don't see any difference in operation or in plug life among any of the brands.
Thanks again!
The bad news, the recommended part number by Bosch run too hot!
How often do you change your plugs to have tried so many different brands?
Just do a search, and you will see how bad Bosch run in Rangers! However,
Bosch run just fine in my gasoline Mercedes.
This has not been my experience.
Every 40-50,000 miles. My Ranger has 185,000 miles on it.
That's why I was asking you: no search turned up anything concrete, and you seemed to have something more specific to offer.
Bosch run just fine in my 2001 Subaru Forester -- that's what came in it from the factory. Ditto for my 1966 Volkswagen Beetle. Glad to hear they work well for your Mercedes
So would it be correct to say that, in your educated opinion, you would not use Bosch plugs in a Ranger because of past experience? Or, is it because of something you heard? Forgive me but I don't recall if you mentioned it previously -- have you used Bosch plugs in an EDIS vehicle?
Try running Motorcraft double platinum, or finewire platinum and they will run 100K miles without a problem (assuming no other problem to foul plugs)!!
Or do you just enjoy changing spark plugs?
Yes, Bosch plugs were causing a misfire in my 3.0L Ranger...
