Going a size up
miller time
rockfalls IL
Ok if I get 33-12.5 will they rub the frame when I turn
I got a 3in body lift
Thanks for the help
what do you have now??? 32x??? how much backspacing on your wheels? cant just ask if it will rub or not if we dont know what you already have.
Also need to know rim size/backspacing.
Although I would think 33s would rub all over the place with just a body lift.
I got 15-10 rims they are America racing rims I don't know the back spacing
Yes I have 32s now
32x? 10.5, 11.5, 12.5??? You do not give enough info. You really should use the search function. 10 inch rims will most likely rub something on the suspension without a proper lift. A bl does not always solve an issue with taller tires. Can't help you if you don't know the backspacing of the rims. Incorrect backspacing can cause issues with taller/wider tires.
