Trump8MyKids
Had to miss school and work last Monday due to me having to drain my diff oil because my diff ate up my abs sensor (probably should have been a sign from the start). Something as of earlier today is making a terrible clunk inside of there. originally it happened whenever I’d let off the gas but now it happens regardless of my accelerator pedal position. I was told by somebody on here to check for play in my rear differential (wanted to check carrier bearings) but I later found out the parking brake was set by my girlfriend seeing I was on ramps and I didn’t set it. Not sure if that would affect the results. The noise only happens over 25 mph. Any ideas on what the noise could be? Everybody I have talked to about it is baffled, as am I. Any help would be appreciated!
