- Sep 30, 2012
- Manual
also to clarify the axle will be abused and worked hard. also which one would be closer to the same length of a 79 bronco dana 44?
Only the 4.0 rangers had the 8.8, and even then its only 28 spline. The 31 spline won't fit in the 28 spline housing. You can get an 8.8 from a full size truck and bolt on the disc brakes with slight mods. Since you have the 60 available, I'd really go with that. The 14b might be cheap and plentiful, but its an anchor, and did you know the hub/wheel is held on by only a snap ring? I've had a real bad experience with the 14b, so me personally I stay away from them, but others have success with them....
SVT
was the dana 70 a full floating rear and did they make it a from factory with a limited slip?
