AllBlackBimmer
I've gotten good feedback on this site for numerous things, so here goes:
I am getting my transmission rebuild.... 5r55e transmission. (04 XLT 4x4 4.0 automatic, only had 68,000 miles)
1.) In-theory, if re-built "well" there long term life of a re-built trans should be no different than a new trans correct? perhaps this doesn't matter, as I may pony up $250 for a 3 yr/50,000 warranty on it...
2.) The shop doing it specializes in transmissions, and says every 2 years or 25,000 to drop the pan/replace filter/replace fluid in pan which seems like good maintenance on it... any comments to that? I think Ford recommended every 30k or so, so that shops recommendation seems to be in line and good practice regarding maintenance.
3.) I have 31" tires with 4.10 gearing... I know some rangers came with 31"s... but, would I get any benefits of auxiliary trans cooler? (I am not sure if my truck has an OEM one or not , will check when I get it back) obviously running larger tires is kind of like towing a small trailer all the time. Is running larger tires killing my transmission?
I have only owned the truck 2.5 months, and do not know the full history of the truck or service... only limited carfax info. It came with the 31" tires.
Backstory is, truck was fine for first 2 months of ownership, every now and again it would shift hard into 2ns (what ive read is "normal" for Fords)... one day in stop and go traffic O/D light was blinking and shifting very rough. Took it to a Ford dealer the next day, and they scanned it and told me there was a TSB for the shift solenoid... wanted $800 to fix. So instead I took it to a trans specialist shop, and when they dropped the pan, they found some crap in it, and recommended a full rebuild. They said they will getting a new valve body that has some updates to it that is recommended.
