93TurboRanger
I apologize if this has been talked about before, but I have done a lot of searching and cannot seem to find an exact answer on this. I am getting ready to pick up a spare NA 2.3 motor and 5-speed trans out of a 97 Ranger and was wondering what else do I need to get going with a turbo setup? As far as I understand, all 2.3 blocks are the same (except the turbo drain hole obviously but you can always tap into the oil pan for this). The turbo blocks had forged pistons. Do the turbo and NA motors share the same internals otherwise? And which cylinder head should I use? Will a 4 plug turbo head bolt on this 97 2.3 block? Also which intake manifold is best and will bolt up? This will be going in my newly acquired 93 Ranger 2.3 5-speed 2wd. Also can I get this tranny rebuilt to handle about 300-400 hp?
