- Aug 7, 2007
- Manual
I did the timing belt on my Honda in an hour and needed no special tools.
The pushrod 4.0 you gotta take the heads off to get the lifters out. That's about $200 in parts just to get the lifters in your hands--not to mention the fantastic amount of work involved.
Old Rangers aren't hard to work on though. It's the thing I like about them.
Will, pushrod 4.0Ls are old Rangers now.
And 2.9Ls had the exact same issue. So, to get a V6 engine that precedes that issue, you have to go back to 1985. I don't think anyone can reasonably call that FBC 2.8L "easy to work on." Maybe easy to remove and haul to the scrapper.
I can do the timing belt on my Prizm (Corolla) in about two hours, with no "special" tools, but it does require special techniques such as unbolting three of four engine mounts, jacking up the vehicle, unbolting the A/C compressor, and removing the water pump pulley.
The first time requires an impact wrench (to break the locktite off the harmonic balancer bolt). But some folks with more guts than me use a breaker bar against the suspension and the vehicle starter motor. Just putting it in 5th gear isn't enough; I walked the vehicle uphill with the (good) parking brake on that way.
