86MUDRCJ
I have decided that my truck will be a diesel... Cummins powered ranger! Why the reason? Well my answer is pretty much because I can.lol now all I gotta do is stock pile parts. Cant wait to get it started!
Never really been a fan of them, and everyone tells me they have their problems... Many problems.dont like duramax?
6.2-6.5 pretty easy for parts
Mines going to be 4bt powered 3rd gen. I personally like the 4bt just for simplicity and how reliable they are. They fit in pretty good and are just fun all around.
If you do put one in, do the kdp, put a Denny T fuel pin in, 3200 Gov spring and hx 40 turbo and have at it.
dont like duramax?
6.2 and 6.5 are detroit diesels, not duramax. Even so, the torque the 4bt makes is good for it's size, 330lb-ft. The 6.2 only made up to 257lb-ft in civilian form, the CUCV's had 330lb-ft though. The 6.5 would be ok, as they made up to 440lb-ft but trying to find one standalone is pretty hard (and I wouldn't want to ruin a nice C/K 2500/3500 as I do like the look of those trucks), not to mention you have a much larger 90 degree V engine to try and shoehorn in there.
Same here and suprisingly I can get one for pretty cheap. Stupid question... What is a kdp?
The advantage of that 90 degree V engine is that you have less overall engine height to deal with. The 4BT practically necessitates a 4"+ suspension lift to facilitate oil pan to front differential clearance in a 4x4 Ranger. To some people this is a moot point because they wanted a suspension lift anyway but not everyone wants one. I think you could get away with less suspension lift with the 6.5.
I already have 4" lift but plannin on runnin a 6".The advantage of that 90 degree V engine is that you have less overall engine height to deal with. The 4BT practically necessitates a 4"+ suspension lift to facilitate oil pan to front differential clearance in a 4x4 Ranger. To some people this is a moot point because they wanted a suspension lift anyway but not everyone wants one. I think you could get away with less suspension lift with the 6.5.
thanks!kdp = Killer Dowel Pin.
what setup would you reccomend? Coils off a f150 or superduty?A 2wd with no crossmember trimming and a 2" body lift will clear the turbo to intake pipe, with very light rubbing on the hood insulation. (goes over the valve covers.)
With a 4x4 you will need to cut the pan to clear the crossmember, but it can be done at stock height without much of a problem. Yes, you will need springs that can hold the extra weight (about 750lbs of engine plus a heavier than stock trans.)
where im at 4bt is easier to find and like stated I dont want tear open a complete truck if I dont have to.6.2 and 6.5 are detroit diesels, not duramax. Even so, the torque the 4bt makes is good for it's size, 330lb-ft. The 6.2 only made up to 257lb-ft in civilian form, the CUCV's had 330lb-ft though. The 6.5 would be ok, as they made up to 440lb-ft but trying to find one standalone is pretty hard (and I wouldn't want to ruin a nice C/K 2500/3500 as I do like the look of those trucks), not to mention you have a much larger 90 degree V engine to try and shoehorn in there.
thanks!
I think many of the people that say the 6.2/6.5 has problems are really referring to the Olds diesel of about the same era and think the 6.2/6.5 are based on gas engines modified to accept diesel. It's an ok engine and there's many still around to prove that.
