Gears needed after sas
NEVERDONE86
Solid Axle Swap
Rio Rancho, NM
Ok..... Took the ranger out for a drive today in 2x. Couldn't get it going over 35 mph. I didn't do my research and now the engine is screaming to go 35. What gear ratio would you guys suggest for me?
I pulled out the stock axles with 3.73s and now I'm running 33" tires with a 4.10
I love the torque it has now but I can't take it anywhere without trailering it. All I want is 55 mph.
That doesn't sound like a bad ratio for that size tire. What rpm are you doing at 35 mph?
Something defiantly wrong and it's not your gearing, sounds more like 4 low gearing. With 33" and 4.10 gears, you should be turning 2720 rpm's in direct drive at 65 mph, see chart up in tech library.
Dave
with a 2.9 456 gears may be ideal with 33's on the street and 35's off road.
^^^ I agree. I have 5.13's to put in my b-2 with 35" tires. But the OP's problem isn't what gears but what he's experiencing with what he has.
