Gearing
RangerBoy94
Northern California
I was wondering what gears are in my truck??? It there a way to tell without taking the axle apart?? The reason why I'm asking is because when I get 33's on it its gonna be a little while before I regear it so I was wondering if I could run 33's with stock gearing.:dunno:
door sticker, check axle code, check TRS tech library to see what code is your ratio.
or crawl under the truck and check the rear dif cover, it has a tag with another series of numbers, copy em and check the tech library to learn how to read that code.
4.0?
yes.
dont tow:icon_thumby:
he means exactly that. dont tow shit with it if u get 33"s and keep that gearing
Well I don't plan on towing. Towing is just gonna put to much load on the truck and the stock gearing will bog the engine down???
Yep, its hard on the whole drivetrain to do so. However, 33 and 3.73's are very do-able. I've been doing it for 6 months now. On the freeway you either have to do 75 with OD on, or 55-60 with OD off. Round town I leave OD off and drive normal. I actually get around 290 miles a tank (mostly freeway) like this.
It all depends on how you drive. If you can find a gear that will keep the rpms up around 2500, you could tow with it. Thing is, off of your stock tires, I'm guessing you'll have 15% less torque at the ground and that means more clutch wear, and a 15% less effective clutch to get it moving. It means that the motor will typically be required to deliver 15% more torque which means more heat and more wear on the engine. My '91 Ranger (most of it still lives in my '89 B2) came with 3.55s and 29" 235-75/15s. When I went to 31s, we had 4.10s installed and it stayed the same. 33s would mean 4.56s to keep it as nearly correct as possible.
I hate riding with people who think they know how to drive. I let someone drive my diesel Passat and he's slipping the clutch on every shift. I told him, try letting the clutch all the way up before you add power. So he tries it and says, "Wow, you really can do that with this diesel," and I said, "No, that's how the **** you are supposed to drive anything!"
The gear spacing is the same no matter what size tires you have. With bigger tires, your engine thinks it's just hauling a bigger load. You have to give it a little more time to accelerate because it's down 15% in torque, and let the clutch up before you give it power so you don't wear it out. Doing the clutch and gas simultaneously is amatuer and kills the clutch. A clutch will outlast the truck if you drive it right. Brakes last 50,000, or 30,000, and they are slipped as a rule. A clutch just gets you rolling from a stop and shouldn't see heat after that.
Don't hack away at it like you are churning butter and you could be fine with 3.73s and 33s for a long time. I had 4.10s and 35s before and it was alright. I was glad to get the 31s back on. I like lots of gear.
theres a trans builder i know that did some load calculations for tires leverage/wt for comparatives.
with 42's and 410's in my truck its like towing 7k
with the 37's its like towing nearly 4 k
with 33's its under tire.
i cant find the sheet....it was based on actual weight of the tire/steel wheel combo verse stock gearing for a 4x4 suburban with a big block...91 iirc....it had a 4l80.
with a stick you can tow occasionally ...but with an auto i would suggest a big cooler in addition to the oem stuff.
NAW!, the motor will just reach operating temp that much quicker (assuming the cooler is an internal radiator type) :icon_twisted: jk
I will be going with 4.88's with my 33's pretty soon. Plenty of gear :thefinger:
im running 32's on 3.55's without any problems, though i have no balls and my highway MPG is wicked!
im putting 4.56 in it this weekend.
