Gear Up your Ford Ranger with new Zroadz Overland Rack!
carid
Supporting Vendor
Cranbury, NJ
The ultimate load carrying capacity is a dream of every truck owner, no matter how often and how much cargo do you need to carry. Modern truck bed racks allow you to achieve this goal, but most of them don't provide enough bed space and limit the access to your gear. Luckily, Zroadz has got a solution to address that - a new Overland Rack system with 800 lbs. on-road load capacity and 400 lbs. off-road load capacity.
This innovative truck bed accessory mounting system is perfect for hauling rooftop tents, and various accessories, such as off-road jacks, spare fuel and water, tools, and anything else you might need for your outdoor adventures. Hybrid heavy gauge steel and aluminum construction make this truck rack the best companion for your Ranger.
ZROADZ® - Overland Rack
Features:
  • Bolt-On installation
  • Light weight aluminum gates on both sdes for easy access to the truck bed
  • 800 lbs. on-road load capacity and 400 lbs. off-road load capacity
  • TIG welded construction
  • Multi wlot and thru hole accessory mounting provisions
  • Steel channel primary structural support members
  • Aluminum channel cecondary support members
  • Three step powder coating process with texture black finish
  • Accessory mounting plates throughout framework
  • Designed and manufactured in the USA by ZROADZ LED, Inc.
  • Limited lifetime product warranty, 3 year warranty on the finish
Includes:
- Overland Rack
- Side Access Doors
- 3" ZROADZ LED Pod Lights (4)
- Universal Wiring Harness
Get more from your outdoor adventures with Zroadz Overland Rack!​
Cool looking rack.
