the manuals call for Mercron V on any M50D transmissioin.....the only difference on the internals in the M50D-R1 that was installed in the '00 and older Rangers and the M50D-R1HD that was installed in the '01+ Rangers is the gearing....If this is for the '93 in your profile, it's Mercon ATF regardless of what trans you got (be sure it's "Mercon" (or Mercon/Dextron III) and not "Mercon V" or any variant like that, the 5-speeds don't shift well on Mercon V unless they call for it ('98up IIRC)).
Edit, takes about 2.75 qts.
Umm, no...
Go look at the manuals for real (I just went and did myself), they all call for "Mercon" (Ford spec XT-2-QDX) in manual transmissions all the way up until this year's model (2008). The AUTOS started calling for Merc V in '97 (XT-5-QM).
Ford doesn't license regular Mercon anymore and they say that Mercon V is now suitable for all applications that used to call for regular Mercon.
