Gauge Problems
Ryannn
Carson City, NV
Temp never moves from the C. How would i go about fixing this? Would I replace the sensor?
The Battery Gauge when the truck is off is all the way to the left, and when turned on it goes to the center, but when I use my turn signal it twitches to the left. Help?
-Ryan
Im not sure about the temp. but the battery sounds normal. It doesn't read when its off. thats why it goes to the left. your turn signal use a bit of power so thats why it would twich. I have seen it in my trucks. more so when I have more things on.
Hmm Alright, Never seen a Truck do that before.. my F350 doesnt even do that... haha, so i was just curious. Thanks.
Still need some help with the Temp?
I think its becasue the alternator has a small power output. vs whats in your F350
The temp gauge problem is often a dirty connection at the sensor, wriggling it about will often fix it for a while. My amp gauge twitches in time with the turn signals but the actual battery voltage stays constant, it's always done it, I just ignore it.
