Shitbox
Does anyone know any common problems with where the voltage regulator for the gauge cluster gets its power. Tried a different cluster, fuel and temp dont work. Replaced sensor and sending unit . 2.8l 1985 b2
Yeah I already did that test it didnt work , I ended up puting an aftermarket gauge and sensor and will be doing the same for the fuel, I just got tired of trying to figuring out why it didnt have power . This thing sat for 10 years and I'm already about 2k over budgetFind the temperature sensor on the engine and unplug it. With the key in run, engine off, have someone watch the temp gauge as you take the wire to the sensor and ground it to a good ground on the engine block. The gauge should swing full scale hot or cold. Then take the sensor wire off ground and let it hang in the air. The gauge should swing opposite full scale. If it passes this test, it will verify you do have voltage to the gauge and the gauge and the wiring are good to the sensor.
Actually that solution was probably the best. What in the world is "normal" anyway on the gauge? Now you have real numbers.
