gauge cluster swap
tmar04
are gauge clusters on same year B2 interchangeable? I have 87 b2 w/o tach. also have 87 b2, donor veh, w/ tach cluster. is this simple swap? thanks to all
The wiring harness is different so it's not a plug and play swap.
I wanted to do that very swap only with a Ranger but didn't want to do it bad enough to modify the harness.
so if i swap wiring harness also, it will work ok?
I just swapped a cluster with a tach out of my donor 88 B2 into a 92 ranger and everything hooked up right and works good. you just have to drive it a bit for the tach to get...... calibrated?
